Most of the configurations I have in the home page are lists; but as I scroll, it is hard to tell the difference between one section and another one.
The header underline certainly helps but the effect makes the header looks like it belongs to the list on top of it.
I have two suggestions:
A simple change could be just support a header overline in addition to the existing underline (first image attached)
Another suggestion (my preference, second image attached) would be to display sections as cards, similar to the homepage shortcuts, where the background of the section is slightly different than the background of the homepage
When scrolling the homepage it is hard to tell the difference between homepage sections, especially lists.
Polished Hompage UI, clear separation between sections.
