Search should use sort artist/album/track tags
When I search artists/tracks/albums, the sort artist/track/album should be used to populate the search. For example if i search kikuo, it should match tracks with the sortartist “kikuo”, even tho the artist is “きくお”.
It’s difficult to search for music tagged in other languages/scripts
Makes it significantly easier, and in some cases possible at all, to search for music tagged in non-english languages. Also allows users to add hidden keywords they want to be matched in search
Other application solutions
Feishin (desktop client) has this feature as described, and I seriously miss it on symfonium!
It already allows searching by romanized names. Can’t handle kanji, but hiragana and katakana can already be searched via the romaji counterpart.
Can’t tell in your screenshot, do you have “All artists” enabled in your search? Because “Album artist” is clearly disabled.
I checked with a cover of 雨とべとら by 雨海ルカ, which romanizes to “Ame to petora” by “Amagai Ruka”.
As you can see, searching “petora” correctly finds the track. Searching “Ruka” also brings up the artist. (Searching “ame” or “Amagai” will have no results.)
Hence in your example, it should in fact already find きくお if your tracks are tagged as such and you search “kikuo”. For example, you can search “tekunaro” and the first track in that screenshot should show up.
This is a neat feature! it seems to work for me with tracks but not artists. Not sure what’s up with that, I have everything selected in the search filter. Either way, this does not cover all cases. For example 이달의 소녀 is romanized as “idalui sonyeo” (well. it’s one of the ways you can romanize that, which is another problem with relying on romanization), but the sort name is “Loona”. I also have music tagged in Greek and Amharic, neither of which I could expect autoromanization support for.
The search is not searching on an all related artists as this is a mobile app and mobile apps can’t handle such multi millions rows queries properly.
Maybe there can be a setting to search with server search instead of local on device search?
