Search in settings
Please add search in settings.
Save time in getting to the required setting(s).
It would help find the required setting(s) quickly.
I very much agree with this feature request. With an ever-changing, and expanding program that is highly configurable. This option really makes sense. I believe if a user goes into settings, and see the search box at the top, it might cut down on some support form topics that are from users who don’t know a configuration item exists or simply doesn’t know where to find it. There will be some options, now, that will need to point to a destination instead of an exact one, because of per output device options.
In case anyone doesn’t know that this exists:
Having it in-app would be convenient. But if it were easy to add, I’m sure it would’ve be been done already. Link above helps give an overview and you can easily search on the site for any setting you may be looking for.
