Description:
When accessing the search functionality, the search view sometimes only shows a gray background, and the search bar is positioned above the visible screen area, making it inaccessible.
Steps to Reproduce:
- Navigate to the search functionality within the application.
- Observe the display of the search view.
Expected Behavior:
The search view should display the search bar within the visible area of the screen, allowing users to interact with it.
Actual Behavior:
The search view shows only a gray background, and the search bar is positioned above the screen, making it unreachable.
Environment:
- Symfony version: 11.4.0
- OS: Android 14
- Screen Size: 21:9
Upload description: formeo
It appears that the background does not support scrolling, which may be causing the issue. Implementing scrolling functionality for the background could potentially resolve the problem.
