Scrolling control via remote (OK button and D-pad) on Android TV
Add the ability to scroll playlists and folder contents on Android TV using the remote control — either with the D-pad (Up/Down) or by pressing and holding the OK button to enable cursor (air mouse) scrolling.
This should allow viewing all items that are currently outside the visible screen area.
On Android TV, when navigating large playlists or folders, it’s impossible to see or reach items beyond the visible list without a connected mouse or touch input.
Remote control navigation stops at the visible edge, blocking access to the rest of the content.
• Enables full navigation using only the standard remote.
• Improves usability for Android TV users without external input devices.
• Makes the interface consistent and accessible across all Android TV devices.
• Reduces user frustration and increases engagement with media content.
Be sure to actually use the Android TV version, then open a proper issue as it works on my devices.
