Scrobbler Integration
Option to Connect Scrobbler apps like Last.FM
Scrobbler integration like LastFM would help store their listening data for their own music files as well
Integration would help track listening apps from Symfonium also to be captured along with multiple apps, streaming services that people use.
Other application solutions
Blackplayer android music player app has this feature.
I suggest you use Pano Scrobbler as it makes this easier by being able to scrobble any music app you have.
Yep I second panoscrobbler. Scrobbles from every app enabled in settings and works without issues
Thirded!
Also, I do have to confess that it took me a looong time to realise the name was an allusion to Pain au chocolat
