Scalable Ratings Bar
Hi,
I’m wondering if it’s possible to change the ratings bar size implementation from two static sizes to similar to the String bars. Scalable with a multiplier.
Thanks,
No problem, just a nice to have. Current implementation is good.
Allows more options for a bigger or smaller ratings bar.
