Hi, i discovered a problem. Im not sure what is causing it but i managed to reproduce it and upload log in this url Symfonium: Secure file sharing with this name debug-20240912_214452.zip.
About the issue: when i play a playlist A, shuffle order to random then shuffle back, it reverts list order as initial playlist A, it works as expected OK. But when i use the app, close it, open it again etc, play another playlist B get back to playlist A (which was already shuffled to random) and remove shuffle to put list back like initial playlist A, it stays shuffled so i can’t get initial order of playlist A back
It’s annoying because sometime i like to play random music, but when i have a song a like, i want to play the song of same artists (which was next to this song in initial order) but when this bug occurs, i can’t get my playlist A initial order.
Thanks, i hope you will find a solution.
biji
Upload description: biji1
It’s caused by having a playlist played with shuffle random on, then switching playlist, then disable shuffle random. See screenshot1, list is ok, i did steps to reproduce then screenshot2 is list that has the first random shuffle as “not shuffle” but it is not the initial ordered list of the playlist
Play a playlist A, set in shuffle random, play another playlist B, play back playlist A, remove shuffle. List is now unordered
