Retain player state option not working
Hi, I have enabled the retain player state option in the settings and when I close the app and reopen, the player state is not restored. If I remember correctly this option used to work before I updated to beta version I maybe wrong.
Upload description: The log file is uploaded and is named “debug-log-ArmourArsenal”
Android Version: 12
Symfonium Version: 7.2.0B1(1209)
Media Provider: Box (Single folder with all >700 mp3 songs 192-320 kbps 44.1khz)
1.) Open symfonium and enable retain player state and remember last renderer
2.) Play a song half way through
3.) Close the app, remove from background and reopen it.
4.) The app opens but doesn’t remember player state.
Box
You miss read the option, what you are looking for is the option playback state saving that is 4 rows above :wink:
Damn I really should delete this post, this is embarrassing :sweat_smile:
Well it can serve others who also can’t read :stuck_out_tongue:
May I ask what happened to the option “Playback state saving” mentioned here? I absolutely cannot find it on this settings page (“Settings” → “Playback” → “Playback”).
It is also not mentioned here:
Well, there is “Min. Play time before saving before saving resume point”. Is that related? But it says it might not work for all media sources. I am using Jellyfin. Is it supposed to work with Jellyfin?
My actual problem: I am playing audiobooks via Jellyfin and would like to resume the audiobooks where I left off.
