The replaygain shows it is working but the volume change isn’t immediately noticeable and I am unsure if it is actually working.
I scanned my files and yesterday no replay gain icon appeared. I then re-scanned it without the “android library” option and scanned them manually through the app and this morning the RG Gain (Track) appeared and disappeared when I turned it off. However, I wasn’t sure there was an audible difference between having it on vs having it off- since it should have been a -9db difference. So I scanned a log when playing music on the drive home. I hope this is sufficient. I can record another, if necessary.
debug-20230829_184027.zip (37.9 KB)
