Replay gain not applying. On/Off settings have no effect
Replay gain does not apply to tracks. Worked in the past, but the setting has no effect on tracks volumes. Other players are applying it correctly, so the files are in working condition.
Logs have been uploaded.
Upload description: Picklepopper - Replay gain tags not applying correctly
I have uninstalled and reinstalled multiple times and have started fresh with no backup. All results end with the same issue.
Play multiple tracks in a playlist and hear the extreme differences in audio loudness.
2024-12-06 23:51:57.450 Verbose ReplayGainParser Replay gain skipped: false - (Off, RG2)
Replay gain is off in those logs …
You need to enable replay gain then start some media.
Apologies. I must have forgotten to toggle it back on when I was troubleshooting it. I confirmed no changes again with it on.
I’ve uploaded new logs.
RG is properly applied for the last 2 media and was still off for the first.
2024-12-07 05:16:24.820 Verbose ReplayGainParser  Replay gain skipped: false - (Off, RG2)
2024-12-07 05:16:24.821 Verbose ReplayGainAudioProcessor  Volume [0.0/0.0]: 1.0
2024-12-07 05:17:32.162 Verbose ReplayGainParser  Media RG: Album=-10.14 / Track=-10.59 [(Track, RG2)]
2024-12-07 05:17:32.164 Verbose ReplayGainParser  Final gain: -10.59
2024-12-07 05:17:32.164 Verbose ReplayGainAudioProcessor  Volume [0.0/-10.59]: 0.2954608888479339
2024-12-07 05:17:41.014 Verbose ReplayGainParser  Media RG: Album=-6.53 / Track=-5.7 [(Track, RG2)]
2024-12-07 05:17:41.015 Verbose ReplayGainParser  Final gain: -5.7
2024-12-07 05:17:41.015 Verbose ReplayGainAudioProcessor  Volume [0.0/-5.7]: 0.5188000389289611
2024-12-07 05:17:55.499 Verbose ReplayGainParser  Media RG: Album=-11.64 / Track=-11.64 [(Track, RG2)]
2024-12-07 05:17:55.500 Verbose ReplayGainParser  Final gain: -11.64
2024-12-07 05:17:55.501 Verbose ReplayGainAudioProcessor  Volume [0.0/-11.64]: 0.2618183008218985
It doesn’t reflect that though with the audio. With every other and player and this one sometime ago, the audio would be very quite since I tagged my tracks at -18LUFS vs. having replay gain off.
Now even when it says it’s on, it’s just as loud and the setting in the app for “normalization” doesn’t have any effect.
Thank you for your response and looking into this.
Then you have enabled hires settings that disable all processors.
Oh, wow. I’ve been dealing with this issue for like a year and to think it was that setting. This actually solved my issue, thanks a ton.
I’d recommend putting a disclaimer that tueing on HiRes will disable replay gain, because that’s a pretty invisible side effect, but again thank you. I’m really happy to have your player working perfectly again.
