Testing 3 versions of the same song. two with tagged gains and one with applied gain to the file. -12.11 gain, -20.11, Applied gain file.
Pixel 7 Phone.
Testing though phone built-in speakers,
The only file with a lower volume is the altered file with applied gain playing though plex and emby server.
Logs show that the gain information is being sent to the phone.
Upload description:
cremonies
cremonies1
plex and emby server:
Original Song Gain tags from foobar2000
track gain = -12.11
track peak = 1.496240
album gain = -12.11
album peak = 1.496240
uploaded additional log
Name = cremonies1
restarted song each time settings were changed.
Gain setting = OFF:
1a. plex server
1b. emby server.
gain setting = ON
2a. plex server
2b. emby server.
Cache Playlist to test if streaming causes issue.
Test 1: Plex/Emby Server
Create 3 copies of song and change names to indicate difference.
Use Foobar2000 to change Gain values.
2a. Tag gain -12.11 (Future Rock - Reaching New Heitz)
2b. Tag gain -20.00 (Future Rock - Reaching New Heitz Low)
2c. Song file altered with -12.11 gain (Future Rock - Reaching New Heitz applied)
Load songs onto server.
Plex and Emby scan same media folder.
Connect Sym to Emby.
4a. play each song with gain setting on/off.
Connect Sym to Plex.
5a. play each song with gain setting on/off.
Repeated steps after caching files.
Result:
Syn gain on/off had no effect on all songs played on emby or plex server.
All songs played from Plex server were louder than Emby server.
“Future Rock - Reaching New Heitz applied.mp3” volume was lower on emby and plex server.
You say you don’t hear change then say you hear changes in some cases.
You also have playback cache enabled so if you change tags for cached media some won’t be taken in account.
I have updated the information and procedure to reproduce. I am trying to determine why the same songs on my server are louder when Sym is connected to Plex vs Emby. Also trying to determining if Replay gain is working for me.
It started when i noticed playing though android auto was very loud with the volume turned down low. Removed this factor to determine if playing though phone speaker worked as intended.
Cache was originally turned off. I turned it on to determine if that would change the results.
Originally thought I had issue with emby and plex while testing last night. I needed to test with bluetooth headphones at work.
Result: Emby works. Plex does not work.
Plex is sending its own gain tags that are different from the values I have listed. I have plex “Analyze audio tracks for loudness” turned on.
I removed the file from plex and added it again to remove the plex gain tags.
Log name = plexgainoff
ran the plex Analyze audio tracks for loudness.
log name = plexgainon
Result:
Both sound equally loud.
Additional Note: it is taking long time to play song from plex now with this testing.
I am seeing multiple downloads of the same song stalling from the plex dashboard.
that is just great… whole reason i use plex is for the web browser to easily create playlist but hate plexamp.
Isolated to me or global issue?
maybe they updated API?
Do you think capturing plex’s could work?
[{“albumGain”:“-12.09”,“albumPeak”:“1.000000”,“albumRange”:“3.810352”,“audioChannelLayout”:“stereo”,“bitrate”:128,“channels”:2,“codec”:“mp3”,“displayTitle”:“MP3 (Stereo)”,“extendedDisplayTitle”:“MP3 (Stereo)”,“gain”:“-12.09”,“id”:“71614”,“index”:0,“loudness”:“-5.91”,“lra”:“3.81”,“peak”:“1.000000”,“samplingRate”:44100,“selected”:true,“streamType”:2,“location”:“direct”}]}]}]}]}}
I need to test what they change (if) but it’s not API it’s behavior change.
And no currently I rely on the tags in the file as it works for everything and every case including fully offline. There’s also some missing parts in ExoPlayer to easily pass external values.
