Sorry about that. Not sure why they didn’t show up. I’ve tried to upload logs again, but I’m not sure I did that correctly. Let me know
I’ve done that as well as an uninstall and reinstall. I tried blaming it on my server, but I can’t replicate the issue elsewhere.
I’m aware of that, but it doesn’t seem to make any difference. It also plays very loud for what should be -18 LUFS. Completey arbitrary numbers, but before I had issues, but car stereo could be set volume 19 due to replay gain, and now it has to be set at around 12 for the same volume.
There’s no new logs uploaded on the server with your name or replay gain in the description so if they are can’t find them.
You also need to remember that replay gain normalise the song to a target reference volume, but then you can apply pre amp, EQ, and many things that will make the global sound level way higher.
Anyway I need the logs reproducing the issue to be able to tell anything more.
Sorry, I had stepped away to iOS for a time and ha dno idea where symfonium was keeping it’s local files. I figured it out finally and have uploaded via the web interface.
Okay, it doesn’t sound like it, but we can assume that I’m mistaken. Can you explain why the audio is so much louder in this app currently than before? There is no replay gain added and every other app including this one had my car stereo volume set to a steady 19 vs now being at 12 for this app recently.
Lastly, did you see anything that would show why the app seemingly freezes and doesn’t playback anything until a force close is required?
No EQ or preamp going on. I’ve made sure of it trying to resolve this issue over the past month without having to waste your time.
If we assume the DB issues are consistently the same issue, I find it to lockup and freeze quite often. This is after a reinstall of the app and wiping cache and data even a fresh operating system install and not restoring the backup I have.
Do not mix issues, the lock during sync occurs when there’s sync, if you start sync often or add new songs on your server often that triggers sync often then it can happen often.
For the freeze open an issue with logs, but there’s a sync running in previous logs, if you have not added songs then either you forced sync or the server returns something strange that generate the sync.
Only logs can tell from before the sync starts to know why.
Okay, the replay gain seems like a dead issue for answers.
So, let me make this easier for the community and make a new thread in a day or two so I can have time to capture some logs at key points where the app isn’t responding.
Sorry for mixing issues. I will more or less repeat what I’ve already said for legibility in search for the forum.
Okay, for any future people that have this issue I discovered mine and hopefully it’s the same for you.
It’s not an really an app issue, I had set server defined transcoding in Navidrome and that somehow broke replaygain. Disabling that and letting symfonium setting the transcode fixed the issue.
