When I listen to a mix of songs from different albums the volume is very irregular. I have activated Replay Gain in Symfonium and try between parameters but there are no changes in volume. I have this problem mostly with the Android Tv App. This doesnt happen directly with PlexAmp where volume of songs are similar. I’ve used Foorbar2000 to check Replay Gain Tags are included in music files but I can’t find the problem. Even when I try different parameters of replay gain option in Symfonium, it seems that there are no changes applied.
Android TV
Plex
Open the app and play mixed songs.
Arielb Replay Gain
