Replay Gain does not work with flac
Replay Gain works with mp3 but not with flac. tagged with foobar2000.
with another musicplayer (poweramp) it works
debug.log (34,2 KB)
Hum that’s strange the TAG is here (with wrong case but still it should work).
Can you send me that flac file in private so I can repro and fix, it’s probably nothing but need a repro :frowning:
how can i send it to you?
Depends on the size but either upload here or use Google drive.
https://drive.google.com/file/d/1VTvYB3qfdAo75Z15pYrReNX7buLMw4Pv/view?usp=sharing
Ok thanks, it’s effectively a lower case tags issue with vorbis tags.
Will be fixed for next release.
