Renaming Audio files in Local Providers
So recently, i been trying to bulk rename some of my audio tracks, and one of the issues that i faced was, whenever i renamed a certain song, in the symfonium, it would lose sll the user rating, favorite and the ability to be playable in a playlist, basically unusable. the app tries to act as if it’s a new audio file and leave behind whatever it had, it’s really frustrating because this way, all my data gets deleted whenever i rename an audio
Upload description: renaming files issue - switchyftw
thank you
  1. interact with an audio file first (add to favourite, let it have a playback and add it to a playlist)
  2. rename that specific file to anything else
  3. lunch the app and sync
  4. the whole data in the first step now is gone
Yes the filename is the key, computing a full hash of files is not really possible on a phone.
why is it in many other apps i own, they seem to keep their data no matter what modifications i do to the file? does the app work differently?
so i have to be cautious next time i bulk rename or rename in general?
Most older apps use Android Media Store and rely those IDs.
Some may consider the files the same based on a couple of values, but that’s error prone and very slow specially as I support very very large libraries.
Do I understand correctly that only the filename must remain unchanged?
So I can change the title, artist or genre tag and the playback statistics remain the same?
Yes that’s the choice that was made.
so for instance, let’s say i had a playback data on a certain audio file named “something” and i lose the file, would i regain the data back if i download an alternative audio file with the exact name “something” ? (of course if i restore a back up afterwards)
i did this test on a the same file and the data came back. i basically renamed a file i had data with, lost the data, then renamed back to its original name again that had the data and restored a backup, my data with that file was regained.
Yes the backup will restore based on the filename/path.
