Remove song from device if it was removed from Plex playlist
Hi, I’m using Symphonium with my Plex playlists. All playlists consist of songs, that were not marked as played. After the listening, the song is removed from playlist and after the sync the new ones are being downloaded to device.
When I’m using auto download rules in Symphonium - it doesn’t delete all those played files, even if I manually refresh playlist.
Is there any way to force those deletions (not by hand and by memory)
There’s none for now but if you had filled the template this could have been a feature requests :wink:
