Remove Resume Points
I am using Local device and found out that if I listen to one albums one song and then another and if I come back to the old album I was listening to it resumes (even singles and eps ) which is very irritating to me !! If I switch of the resume point to never it doesn’t track my library itself !! Is there any option to remove or disable resume points with tracking the library ? I don’t think Logs are required for this , if I’m sure, tho i have uploaded it through the app !!Thanks
Upload description: Debug log
It only resume of you press resume. Better explain the issue please.
I dont want to set resume points and it should track my library also !! If i set min play time before saving resume point to never it wont track my library itself , now i dont want to set up resume point itself and also at the same time it should track my library !! I use local device . How should i do this ?
Track what ?
If you disable resume points there’s no resume points, but play counts are still counted.
Continue album listening doesnt track if i disable the resume point !! :grin:
Well that sounds about right no ? :wink:
To resume you need a resume point…
I dont want resume point itself , if i play it should start from first not in between which it doesnt if i keep resume point !! :grin:
This is called continue for a reason…
You can’t have 2 opposite results at the same time.
Use last played albums to see the last played, or don’t use the play button over the row and click the image to then press play instead of resume.
