Record label navigation node
Hi, i’m using Symfonium with a Navidrome instance, i saw from the navigation nodes that there’re some interesting filters like the record label one which for me is very important.
Could you explain me which tags do you consider in order to properly tag my files ?
Thanks for the help :slight_smile:
I do not consider tags when using a server I take what they serve.
Subsonic does not support Record label, so no luck.
Ping @deluan if he have them in it’s database maybe we can expose it.
thanks @Tolriq for the answer now i connect the proposal from yours Subsonic Extension table of exposing more data :slight_smile:
Record label is not currently imported from tags in Navidrome, just because there’s no way to leverage it in Subsonic API, nor in the Web UI. It should be very straightforward to do it though, but as you said, it is not part of the (current) Subsonic API, so can’t really do anything.
If you already had it, we could expose privately like the lastplayed stuff.
But if not, then yes no need to do it sneaky, let’s wait for the extensions.
This is realy sad, that subsonic is not sending “Record Label” “Publisher” information.
Hope this will be extended in next releases. Would be very nice.
Hello I believe that thanks to @deluan’s work Record Labels are now available in Navidrome.
@Tolriq Do you need something more in order to have the record label browsing with Navidrome ?
If the data is returned via the API then it’s already supported since a long time.
Amazing I was waiting for a long time and I must have missed the news for Synfonium’s support.
I was just checking regularly your table of suports and
OpenSubsonic:Tags / Collections is still at NO
My bad I guess :slight_smile:
Labels are supported since day one, and unrelated to collections.
