Rate & Exclude multiple songs with multi-select
Add the ability to exclude and rate multiple songs at once with the multi-select feature. That way I can just search for all my songs with “instrumental” in their name, then select them all, and then exclude/rate them all at once.
I want to exclude my instrumental tracks from my personal mixes however, I have alot of tracks and would like the ability to exclude or rate them 1 star all at once.
Allows users to quickly rate/exclude tracks without having to go to each one and set the setting individually.
The easy way for now is to create a smart playlist and start personal mix on it.
