Firstly, I want to congratulate you on Symfonium. When I was using Kodi I purchased Yatse and thought it was very close to being my music player. Chromecast integration is excellent, and the transfer between different players is seamless. Well done.
Firstly, I don’t have logs (so please don’t delete my ticket!) but I experience random stoppages on large playlists (>5K). For example, Symfonium will play for 3 hours and then just stop - I don’t seem to experience this on smaller playlists (<1K). It also seems worse when connecting to a car stereo or Android Auto, but it is hard to problem solve without turning on debug for an extended period.
Are you okay with a large log file to assist in problem solving?
Well this is something completely different the media seems not supported.
Does media like “Various Artists/All Time Golden Hits (200 Original Super Hits)/Rock ‘n’ Roll Music.flac” or “Carpenters/Gold - Greatest Hits/Solitaire.flac” plays correctly ?
Could either be the file not supported, or an error during offline cache.
Yes, both media examples play perfectly. They are converted to 256kbps on download. I’m sure you have answered this, but what is the location of the offline cache so I can check the converted file?
I would expect that converting 5K media files would take about 13-14 hours, but last time it took less than 2 hours. I have long suspected that Symfonium has record of the converted file, but it has not downloaded correctly into the offline cache.
I can confirm I have many zero sized files, screen attached. The attached log represents me going backwards and forwards in the playlist as Symfonium displays error messages about the file.
Check your server logs at the same time, I’ve added a check for empty file for next release and I do not see how an error would be not caught.
So I’m pretty sure there’s transcoding issue on the server but it returns a valid 0 byte file and no errors leading to this.
