Radio mix and navidrome
Hey all, quick question:
So navidrome now has an instant mix feature which seems to work similarly to symfonium’s radio mix, fetching songs from a similar artists API.
With recent plugin support, there’s now a sonic analysis based implementation which overrides this basic instant mix feature with one that’s based on pure sonic similarity. Seems to use the “getSimilarSongs2” API. I installed this and it’s working perfectly on the standard web UI and feishin.
While going through my media provider settings on Symfonium, I noticed the “use similar tracks for Radio mix” feature, which I enabled. Is this feature supposed to rely on the same API? From my observation it still seems to be fetching similar artists to create the queues.
I don’t so user observation :wink: I do logs and facts.
Anyway of you start a radio mix from a song it will do that.
