Quick Connect for Jellyfin
As saying in previous posts, it would be great to use SSO for jellyfin login. Currently, in my self hosted apps, jellyfin is the only one require a password + login in order to let Symfonium connect. Jellyfin has an SSO plugin which is working well. I have two main questions :
  • Is there a way, like for Plex, to use the jellyfin login web page instead of just login + credentials in order to establish a session
  • If not, is it possible to use the Quick Connect jellyfin code instead ? Thanks to that, users would connect on web browser and compatible apps via SSO, and quick connect for Symfonium client
Thanks :slight_smile:
There is only one way to login to Jellyfin currently
It improves jellyfin security by not letting people connect with credentials
Jellyfin app is based on the web app I think, so the SSO integration works well. There is no Jellyfin clients that support SSO currently
Had to make an account just to bump this. I would love to see this implemented in some way.
Currently I am using LDAP as my backend for my Jellyfin users, meaning if they have 2FA enabled they can log in with a semi colon i.e. “password;123456”
However Symfonium is currently handling the jellyfin login horribly breaks this. I think it’s constantly pinging and updating the user password and instantly invalidating that 2FA code. This isn’t a problem for other apps like Jellyseerr or Feishin.
So cannot use 2FA and symfonium.
Unrelated, open a proper issue.
It’s not unrelated and I’m not opening a new issue because I’m not specifically asking for a fix, maybe another day.
Bumped this thread because using quick connect specifically is something I’d like to see, it solving my LDAP issue is a bonus.
Well I am actually asking for a fix :wink:
There’s nothing more infuriating to be given half the details of a bug and having no way to fix it :wink:
So can you pretty please open the issue ?
