Queue memory issue
Queue is being replaced by separate queue.
If you are listening to queue (a), then create a queue (b), then listen for a while, and switch back to queue (a), and only listen for a bit before leaving, when you come back the next day, you will find that you are still on a queue named (a) and your song position in the queue is still that of queue (a), but all the songs have been replaced [in the same order] with queue (b). Queue (b) is untouched, and queue (a) is effectively overwritten.
Upload description: Uyly_
I’ve been aware of this bug for at least a year.
If you listen for long enough after switching back, the bug doesn’t happen as far as I’m aware.
Symphonium is set up to have unrestricted battery permissions on my phone.
Listen to a queue, change queues, then close the app and open the app again hours later.
