Queue lost or switching to wrong playlist
Hi,
First of all, let me say that I love this app, it is quite near perfect. My only problem is the following:
I use Symfonium to stream from my Navidrome (Subsonic) server. I like to switch between two playback queues: 1. an m3u playlist with all my music in shuffle mode (around 17k tracks), 2. another m3u playlist with about 1700 tracks in shuffle mode also. Both playlists are updated regularly by the server.
The problem is that Symfonium sometimes mixes up those two queues, e.g. I was listening to queue no. 2 last night (on sleep timer) and, this morning, queue 2 is fine but when I switch to queue no. 1, it is based on the wrong playlist.
Both queues are now based on the 1700-tracks playlist, although they are at different places: queue 1 is on track 16 of 1688, queue 2 is on track 24 of 1688.
I don’t know what causes this and have found no consistent way to reproduce, might be the update of the library or playlists, the sleep timer, the length of the playlists?
Thanks in advance for your help,
Upload description: Pascalors
I need logs when it happens or some repro steps else there’s not much I can for now :frowning:
I uploaded the logs as soon as it happened today. It seems to happen when the app is not used for a time and if it syncs with the server.
The media queues are unrelated to the servers and syncs, they are just a current queue and not updated from the source you start them.
I’ll really need more details about some reproduction steps.
I’ve had this happen a few times too. Its hard/impossible to reproduce so I haven’t been able to generate any logs.
Switching queues works initially, but when switching back it seems to overwrite the queue being switched to with the previous one, in my experience. Exiting or switching again doesn’t help so I have to restart the queue/playlist/whatever. Its been happening on or off for me since the very beginning of me using Symfonium (purchased 24.11.22). All in all I’d say it’s only a minor nuisance, being so rare, in my case.
