I’ve got a question regarding the sorting. I’m using a library for my kids radio/audio plays and the sorting is kind of off.
They’re named as follows:
Episode 01 - Title
Episode 10 - Title
Episode 102 - Title
Unfortunately there are a lot of episodes so the new episodes are 3 digits while the old ones are only 2 digits. This results in the 10x episodes showing up before episode 11 which is a like awkward. Emby as the backend sorts them correctly. I’ve attached two screenshots, one from symfonium one from emby to show what I mean.
Is it possible to change the sorting behavior to the order in emby?
The app have different sorting that you can change.
You need to be sure to use the sort title sort if those media have a proper sortitle, or sort by track number. Without logs and the header I have no way to know in what part of the app you are.
If they are the same then it’s normal that the result are similar, sort is alphabetical in Symfonium. Natural sort order on phone is wayy too slow to properly handle all the supported languages, since it’s not something that existing naturally in SQLite.
To fix your issue you just need to set proper sort title to those albums so they are sorted in the order you want.
