Question about AutoEQ and Hi-Res Support on LG V60
I noticed that in the app, I can enable both AutoEQ and Hi-Res support at the same time while playing a hi-res file (24/96). Does this mean the Hi-Res feature isn’t actually working? Or does it just temporarily turn off Hi-Res processing when AutoEQ is enabled?
Also, as a side question, if the app displays 24/96 while playing a song, does that guarantee the audio is not being resampled?
I’m using an LG V60 if that helps with any specifics.
Upload description: kenken1985(Question about AutoEQ and Hi-Res Support on LG V60)
no one can guarantee anything on Android, the DAC can resample, the OS can do what it wants :slight_smile:
The only guarantee is that the audio that leaves Symfonium is as described.
Thanks for the reply. I guess there is really too much variable in android :rofl: As a side note, do Hi-res support apply to locally cached music file?
If the file are cached at hi res
