Hello,
I noticed that if in the original tag of a track I leave the Artist filed empty, Synfonium writes in any case [Unknown Artist] as you can see here:
Is there some setting that let to avoid this and put merely an empty filed?
Also I found out that this string exists everywhere in the album page:
But on the other hand, if I switch in the original tag Artist and Album Artist I have another behaviour.
Let’s take as example the track number 3 in the screenshot above. I have in the original tag Album Artist = Murubutu and Artist = Erica Mou … ok?
If I switch the two tags and use Album Artist = Erica Mou and Artist = Murubutu, that track disappear from the list of the album and Symfonium makes another page album containing that track only, as if the main artist was Erica Mou and not Murubutu.
It seems like it’s making a group by based on Album Artist and not by Artist. Here does exist a setting to decide which tag to use in order to have the track under the same album page?
Always in this album page, if you notice an annoying string “Da” appears before the name of the producer under the track title, why this? Could it be deleted?
I hope I explained myself well, thanks in advance for your support.
