A pull down to sync gesture like the one used for reloading in mobile browsers.
Makes it just a little easier to grow a remote music library by removing the menus required to trigger a sync.
Makes the user experience cleaner by removing a common reason to open settings and makes it just a little easier to switch from music providers since they have this feature already.
A single pull down gesture at the top of the page reloads in mobile browsers and in basically any app that needs to fetch data from a server.
And this is a duplicate, this does not work as soon as you have multiple providers. You usually want to sync one and not have to wait of the large one start to sync first if you can’t control.
