When using blur / blurry background, if the background is bright enough to switch the interface to darker colors then the progress bar is the same color as upcoming audio making it invisible.
Upload description: overlordpotato
The progress bar is barely visible during quiet portions, its just the same black as the unplayed portion.
Set background to blur / blurry
Enable waveform
Play song with bright cover art
