Problem with word by word lyrics
I downloaded some word by word lyrics to test, and while it basically works, most of the time, it doesn’t flow smoothly and it moves jagged. I think this is a lyric file issue though as I have two songs where it works flawlessly.
Upload description: Problem with Timed Lyrics
On screenshot 1, this is one of the songs with lyrics that work flawlessly and you can tell with the way the light is fading from the last word.
On screenshot 2 the light is stuck on the first word while it’s supposed to be on the second to last. There’s also no fading compared to the first screenshot.
I downloaded timed word by word lyrics from songsync and it doesn’t work as intended. For the one that actually works, I cannot remember where I got the lyrics from.
Here are the test files:
Tints below is in the “GOOD SONG” folder, while HUMBLE. is in the “BAD SONG” folder.
Do you know where they get the lyrics from?
[bg:<01:21.521>Hol' <01:21.683>up, <01:21.941><01:22.003>bitch <01:22.212>] I’ve never seen that syntax anywhere.
From SongSync
Once installed, select “Apple Music” as the lyrics provider and choose a popular song (because not all the songs have word by word lyrics). None of the other providers have word by word lyrics either. Otherwise I don’t know where to download word by word lyrics from.
Has this been fixed?
Yeah it should be in the next update
