I created a couple of playlists in Airsonic, and the app recognizes them, no issues there. But when I open one of those playlists, it says they are empty. Any ideas why?
Another screenshot:
Another screenshot:
Is it really that hard to read and fill the template???
The logs are mandatory.
Please provide them when importing the playlist and since you hide the filter option maybe enable it again and check there’s no filter.
Sorry, here you go.
debug-20230207_120802.zip (9.6 KB)
I tried importing that Green Day list again, and now it says “No playlist content to import”. Even though as you can see on my screenshot I did import it yesterday. Well, I imported another one.
The songs can’t be matched, your library is probably not synced.
Airsonic is abandonned so require that you enable the option Compatibility mode.
