Primary and seconday release types are switched
Release types are switched.
I noticed that sometimes the Primary and secondary release types are switched up.
Example:
https://i.imgur.com/ozlNdbB.png
All these files have the exact same tag.
Navidrome Raw Tags shows this for all files:
https://i.imgur.com/yGclaAg.png
But only Symfonium sometimes mixes them up.
Navidrome
  1. Import a new song with single; live as release type tag.
  2. Notice it switched the Live / Single part, which unmerges it from Album view.
These show up fine in other clients like Feishin.
https://i.imgur.com/JfBwKqP.png
Don’t think its necessary in this case cause I can’t perform the action. It’s always there.
I really don’t know how to make things more clear … Why do you check the box that you understand logs are mandatory and then write that you won’t provide them?
Provide the asked logs containing a full sync from Navidrome.
You are right sorry.
While I just did that, I did a full sync in Navidrome first, then a full sync in Symfonium, and the issue is somehow resolved? No clue how. I’m glad it’s resolved though, so I guess we can close this?
Symfonium displays in the order Navidrome send the data. You probably had bad tag, fixed them and now all is synced with the proper data.
Haven’t changed any of those tags since importing them though, and it used to be correct before that. Anyway I’m glad it’s fixed and for the next time Im sure to include the logs. Thanks for the goated music player Tolriq!
