Hello, I had enabled playback cache by setting the size to 1GB and pre cache songs (mobile) to 5 songs and pre cache songs (Wi-Fi) to none. After enabling these settings and playing some FLAC files using Wi-Fi, the songs get cached even though on Wi-Fi it is set to none, because when I scroll trough the song wave bar it immediately starts playing the particular part of song instead of taking time to load when the main playback cache option is turned off.
do let me know if you need anymore info!
Upload description: PBC-AA-debug.log
Media Provider: Google Drive & Box (Haven’t tested with box)
1.) Disable playback cache
2.) Enable playback cache my selecting 1GB as size
3.) Play 2 FLAC files
4.) Play the first FLAC file and scroll through song to ensure it is cache because it starts playing immediately after scrolling the song.
Any provider
