Portion of Cover Reflection not affected by background overlay
Beta
When using the “Cover reflection” background style paired with solid (100% opacity) background overlays, there is a strip of reflected cover art that is unaffected by overlays.
Seems like this part of the reflection is drawn on the Cover panel’s layer instead of the Background’s layer.
This makes it impossible to use the Cover’s Bottom overlay + any Background overlay to create a smooth color transition, since this reflected portion will be unaffected.
See attached NPS style:
nps-Reflection Layer-20261104_161350-symfonium.json (191.6 KB)
  1. Background style set to Cover reflection
  2. Solid Background overlay enabled with 100% opacity
  3. “Full” Cover overlay enabled with 100% opacity
Strip of reflected image will be visible below the Cover panel
Pic 1: Full cover overlay (red) and solid background overlay (blue). No margins. Reflection (white) still visible.
Pic 2: Added Controls and Info overlay (green). This seems to be a layer above the cover reflection, and thus covers it.
No logs, see attached NPS style
In Beta 2, this is now fixed only when the Cover overlay is at 100% opacity.
I probably wasn’t clear that I was hoping for a change at all opacity values. The 100% was just an example to show the issue.
Cover’s Bottom overlay, with opacity less than 100%:
Cover’s Bottom overlay, with opacity at exactly 100%:
Note that it is the Cover’s opacity being set to 100% that is determining whether the Background overlay goes over the reflection. Seems a little odd :person_shrugging:
I think the background overlay should always go over this part of the reflection. Unless there’s a case you have in mind where this is undesirable?
My goal is to have both the Cover’s Bottom overlay and the Background’s overlay at around 50% opacity so that the reflection still shows under the tint.
Currently I can do this with the Controls & Info overlay instead of the Background overlay…
…but this layout doesn’t work well with Floating navigation bars, since the Controls & Info overlay stops at the bar:
Which brings me to a related question: shouldn’t the NPS “Navigation bar overlay” color this region, under the Floating Nav bar? Currently, the only way to color this region is via the NPS Background overlay. (Hence, the issue of this thread.)
NPS Nav bar overlay is always ignored when Floating Nav bars are visible.
