Plex chromecast play queue stops after brief disconnects
I have a wifi mesh setup in my home. When I am casting an Album from Plex to any Chromecast device from my phone, if the phone jumps to another mesh access point the brief disconnection will stop the play queue after the currently playing song finishes.
Basically anytime chromecast has a disconnect its seems the play queue clears or stops. If I am using Plexamp music continues to play even if I leave the house and I can just reconnect the cast to continue control.
I am not sure if this is a issue, a setting I missed or a feature request.
any assistance or advice would be appreciated
Thank You
Symfonium ver 9.0.0 (12584)
Upload description: GJR-oct
Symfonium ver 3.5.0.0b
I am still experiencing the issue of when casting an album or playlist from plex to eg: nest audio and I walk outside and lose wifi briefly the playback will stop after the currently playing song.
Have I missed the setting or is this not possible. When I cast from plexamp it will play all day long regardless of the phone loss of connection. Issue also exists on fire tablet.
When casting music from plex to nest audio is it possible for the music cue to continue playing once the phone or tablet disconnects?
To reproduce this issue turn off the Wi-Fi on the phone while a song is playing. Once the song is finished the playback queue will stop
Plex
The queue is managed by Symfonium so if Symfonium have no access to Chromecast it will stop this is normal.
Your mesh is probably badly configured if you loose connection when switching devices, but you can uncheck the option Playback/Playback/Automatic renderer reset to try to reconnect to Chromecast when this happen.
