Chromecast Audio sometimes show twice in music apps (not only in Symfonium : Poweramp as well, etc..). A workaround would be welcome to only show the device once. The device hide feature is not enough : duplicated devices come back after a while.
debug-20231126_170859.zip (67.8 KB)
Seems that Google apps have implemented a filter for these duplicates (ie : Chrome)
Tolriq
November 26, 2023, 5:04pm
2
Hum technically they have different ids
Does the cast works on both the duplicates in all cases ?
Yes, as far as I have tested : they all work ok
After some googling : duplicate Chromecast is a very common problem.
I have double-checked everything I could from Wifi ARP table to Google Home configuration, and factory reset several times
Tolriq
November 26, 2023, 6:48pm
5
Well Google Play Services quality
Anyway if both routes do work I can hide the second one that arrive, let’s hope it does not trigger other issues for other users.
it has to be tested, yes indeed.
Thanks
That’s a problem of Android 12 I presume, I also have the same problem, the Symfonium app has nothing to do with that.
