Persisting the scrollbar state seems to be implemented on every view I have used in the app, but there’s a particular scenario where the scrollbar is reset to the top.
This issue happens in the playlists view, when I click a playlist for the first time, and when the playlist was automatically imported during the sync of the local device.
Note: If I click the playlist a second time, the issue will not happen for that playlist, but it will happen on any other playlist that I haven’t clicked yet.
Upload description: scrollbar not persisted log
This seems to be an old issue, since I’ve seen it in previous versions.
- Sync your local device and include playlists
- Go to the playlists view
- Scroll down and look for a playlist at the bottom of the list
- Select the playlist, you will get the “your data is being synced with your media provider” message
- Wait for the playlist to load the tracks
- Go back to the playlists view
Issue: the playlist view will scroll to the top instead of staying in the same state it was before.
