Additional playlist sort modes would be great to have. The mode I’d like to request is sort by creation/import time. This would help navigate the playlists for a large library.
I don’t think there’s a way to see what playlists were imported recently. This makes it necessary to remember recent library additions to be able to listen to them locally, favorite them, or download them.
Better discoverability in a large library.
Other applications support a variety of sort modes, and some go a step further with folders and custom ordering.
Note also, syncing a playlist without any changes puts it at the top of the last modified list. That doesn’t seem right. I can send a separate bug report for that if desired.
You still have no added the star endpoint. This kills your battery as it tries to update the favorites quite often.
For the modified, well you are forcing a sync. So technically the playlist is modified since it’s forced. What kind of Playlist is it? (read only / online first / …)
You can just return a static dummy json file to avoid the retries.
I’ll see to use the server modified version even when you force a sync. Let’s hope some servers do not return invalid data that will cause other side effects.
