First off, i love you, mad respect for Yatse and stuff for Kodi, and I’m French so you’re even better
I’m just discovering your new app (didn’t know was from you), I’m like wth it’s so well done ! (Then I see Tolriq, I’m like “of course” :D)
So about the request ;
Long time Plex user (lifetime lisense), they’ve done great with Plexamp, but man not being able to share a playlist (music) with home users is not acceptable. I think it’s the biggest feature requested on Plex forums for many years…
So do u think that would be do-able / thinkable ?
I’m sure u have many other priorities, but I’m sure this one could make many Plexamp users think a lot about ur app !
Btw, if I buy ur app, is it available on Google play store family sharing stuff ?
There’s no magic in apps, if Plex does not support that on the server side, client apps won’t be able too.
It would require another server part to store the data and share it between the devices it’s out of scope of this app. There will be export / import of the playlists but will require export, send by some way and import so not really magic.
Edit for your edit: No family sharing for now Google does not support that for In app. And still does not offer a proper way to have trials for paid apps without subscriptions.
Exact !
Désolé j’etais tout excité à découvrir une nvelle app made by Tolriq, même pas eus le temps de test les options si bien fournies
Pour le thème, j’ai juste l’habitude de quelque soucis sur d’autres apps depuis Android 12 qui veut absolument suivre la teinte du fond d’écran actuel.
Sinon si je peux aider (ou pas hésite pas.a.le faire savoir )
Dans ta bibliothèque il y a je pense une section manquante de Plex (album collection).
Pareil chez Plex, tout ce qu’il reconnaît sont les artistes/albums, pour les compilations faut bricoler en créant manuellement des “album collection”
