Playlist Added Order Not Correct After Syncing with Jellyfin
I received the new update and after syncing the playlists with my server to load the new songs I added to them, the added order defaults to showing the oldest tracks in the playlist at the top even if I change from ascending to descending. I have tried to delete the playlist and re-add from the server with no luck.
Upload description: RiseUpLights
I have checked the files and the “Date Added” fields still show the correct dates even after re-adding the playlist.
Opened the playlist, pressed sync and “Replace with provider version” and the Added order option stays the same. When I change from ascending to descending the order doesn’t change.
Link to video showing steps on a playlist that didn’t have the bug yet so the order was functioning properly: https://drive.google.com/file/d/1pvcD2Ylt7Fu0-wm6nF7boxm_sYsjf8Sr/view?usp=sharing
Thanks will fix, but added order is the added order in the playlist not the date added of the media.
Yes my bad, I didn’t explain it well and picked the wrong metric to go off of but that is the goal to have the added order for the playlist tracks to be sorted by. Thank you for the update!
