Casting via UPNP is not working. Logs made with the following steps:
- Connect to UPNP renderer
- Start playback
- Doesn’t start playing
- Stop playback (clear playlist by holding play button)
Looked at the logs, but there is too much information, and I have no idea.
Upload description: EricthePeric3
Have refreshed all metadata in Plex, and synced Symfonium manually. Also rebooted renderer, as well as my Synology.
Plex
What have you tried ?
Like enabling the proxy mode for the renderer in Symfonium?
Haven’t changed anything in months, do the logs say where the problem lies?
Setting proxy (and applying) doesn’t change anything by the way, same issue.
EDIT 2: seems to only affect recently added music. I’ll go look into the files.
The logs says as always that the file is accepted by your Wiim, what happens next is between the wiim and plex as all your previous issues
Sadly I can’t read the logs very well so that’s why I asked for help. Will go and see if I can get it fixed. Thanks again!
