Playing via UPnP not starting track playback
Beta
When connecting to my soundbar via UPnP first and then selecting a track to play, playback just wont begin. Only by disconnecting from UPnP, and, then starting playback locally, then going back to UPnP, can I get the playback to begin on soundbar.
Navidrome
  1. Connect to soundbar via UPnP
  2. Start song playback
  3. Playback doesnt start but volume control of soundbar is possible from phone.
  4. Disconnect and start local playback.
  5. Connect back to soundbar
thekingpin
Did it worked before ?
Yes it did. It was always rather delayed, as in I would connect and hit play, and, get audio about 3 - 5 seconds later.
There’s no changes in uPnp in beta 1. No changes on Navidrome / network side ?
It might be Navidrome actually because Im using a PR release (So I get to use Audiomuse early) and not stable… Totally forgot about that. I have to check Navi logs and report back.
Nothing odd in Navidrome logs. Just says streaming file to symfonium.
OK, seems I disabled alternative UPnP flags some how. Its working again now it seems. Apologies for wasting your time.
