Player randomly switches to first song in queue when clicking another song inside album/playlist
When clicking on any song (that is not the first) inside an album or playlist to start the playback, Symfonium sometimes starts playback of the first song of that album/playlist.
This seems to happen at random, I couldn’t recognize any pattern/trigger, though it could be more frequent when selecting different or the same song(s) rapidly (>1 seconds between clicks).
It happens both when the queue is already playing and when opening up a new one.
It also happens both with music playing and with paused playback.
It does not happen when selecting a song inside the ‘now playing’ queue.
Upload description: sillyrock
I’m having the exact same problem, using Subsonic as a media provider on a Google Pixel 6a.
I’m able to reproduce this issue.
I think happens when the last played song gets moved to the 1st position of the playlist.
I’m using Navidrome (latest stable).
Synfonium 11.1.0 / 127206
That’s not really what I’m having, the song doesn’t go to the first place
(On the video the audio is not properly sync for some reason)
What I need is proper logs.
I uploaded mine in the app with the share logs to support button.
Did you find a resolution to this yet? I am having the same issue. When I drive home tonight I will start the log recording as well. I’m using Onedrive and whenever I select a track on an album the first track is more often than not played, but I can then afterwards select the track I want. It’s a minor annoyance overall but I would like to fix it if possible.
The thread got marked as ‘fixed’ by Tolriq so I’m guessing the issue is solved and the update should roll out very soon (the issue is still there for me but I see no update available yet).
Thank you Tolriq for the quick work!
Yeah, with the last update it now work just fine like before. :+1:
