When playing a track mix the player will sometimes stall at the beginning of the next track. The pause button has a swirling circle as though it’s buffering, but I have pre-cache set to 9 tracks, so it’s already downloaded. If I manually skip forward to the next track and then back again the same song will play without issue.
Disabling cross fades has improved the issue but not fixed it completely.
Upload description: B16wll
Issue occurs most frequently on Lenovo tablet running Android 10, though does happen on S25 with Android 16 but not as often.
Switching off cross fades reduces the issue but does not fix it completely.
No, the tablet does have a Dolby Audio app but it’s disabled because it slows everything down. The tablet is only used for music playback via Bluetooth
Ok, all Symfonium EQ settings were off, and the system EQ was also off but I’ve disabled it in settings too. Will reset logs, have a listen and see what happens.
I think that’s a weird coincidence. My son got home from school today and said the power sockets weren’t working, the breaker had tripped, so the server may well have gone offline whilst I was testing!
