Playback on Pioneer device stops after track even when there is more in the playlist
I want to play a full album via UPnP on my Pioneer devices but it only plays 1 track.
I have a setup with Navidrome as server, if I browse DLNA devices (made posible via upmpdcli) from the Pioneer device there is not such an issue.
Is there any way to fix this?
Upload description: reyostallenberg
The devices are Pioneer MRX-3, MRX-5 and XC-HM86D
None is working
Sadly this is not the solution, I tried toggling all stuff in the renderer settings, nothing is working. Are you aware of any othe solution for Onkyo/Pioneer devices for this kind of thing?
Onkyo and Pioneer are the ‘same’ brand and uses the same protocols.
I postponed my issue to 'after summer as I didn’t have time and do not know how to fulfill the question: “Provide new logs with proxy off. From the logs it’s hard to understand the invalid values.”
I’m under the impression that this is exactly the same problem and that keeping zulphu’s question in the same ticket is more clear for future review.
I’m sorry. You are asking to do it this way (Open your own proper issue) because that is the only way for him to share his logs from the app with you. So see my reply as not sent
Not even 2 devices of the same brand use the same implementation of UPnP.
Yes they all use UPnP like all the other brands, but no the issue is nearly never the same except bad gapless support.
His issue is different as he have gapless disabled so no it is not the same and so requires a different issue. Specially when this issue is marked as closed.
Ok thanks, seems the devices takes age to report stopped after end of track and stays in transitioning too long.
Will fix that part, and try to workaround the invalid data to have gapless else it will cause long delays between tracks.
