Philg
1
Playback speed keeps constantly changing even after changing to maintain playback state also I have uploaded logs following the guide
Upload description: Philg
Tolriq
2
Can you please explain your issue a little better ? Changing how ? When ?
Philg
3
Basically it keeps going back to stock at 1 after changing even when having retain player state on
Tolriq
4
After changing what? Like you select 1.5 and it revert instant to 1.0 or after starting a new queue, or the next song?
Philg
5
It now reverts after the next song but the first time I tried it was immediately I’m on pixel 8
Tolriq
6
If it’s a reset on song change with crossfade or queue load it’s probably fixed in the new beta build.
If you can try thanks.
Philg
7
I’m not on the current Beta how can I Join, play store says it’s full.
Tolriq
8
You can use beta maniac to get a spot, or them wait for next release.
