Playback keeps stopping on Wear OS
The watch in debug mode and connected.
Okay, I’ll give it a shot in the morning and report back
Okay, I think I’ve manage to do the right thing - I’ve uploaded a logcat.txt that I gathered after reproducing the error. Let me know if it was what you needed.
Ok so yes it’s a proper logcat so it’s good I can send you a debug APK.
But do you have the exact time it happened so I can try to see more in those logs? I do not see anything obvious but maybe with exact time it will be easier to see.
Still sick AF so the special APK will be for next week.
For me it happens exactly 1 min into the song on every other song. Let me know when the APK is complete surely appreciated. Thank you for all that you do and get well soon.
The APK won’t do anything more than adding logs, so you could and should already be trying to provide those logs :wink:
Was this issue ever resolved on your end?
Did you ever get this issue resolved?
Did you ever provided the asked logs ? :wink:
Google is waiting for a bug report containing the problem.
How to submit a bug in Android Wear - Wear OS by Google Community.
I’ll try to get bug report when I get home this morning. Which version of the wear os app should I use (I think I remember seeing it updated from the play store recently)? Do I pretty much just do the same thing I did last time?
The last one from PlayStore without enabling the disable offload.
Bug report needs to be captured after the issue arise.
That bug report documentation is a bit confusing - do I reproduce the error then follow the steps to generate a wear os bug report and then follow the steps to generate a bug report from my android phone? Or is it reproduce the error, generate phone bug report, then wear os one?
It seems a bit outdated the article - just notice that the watch app on phone has a “take cross-device bug report” which would seem to generate both the necessary bug reports
I’ve got the bug report - should I just upload it the same way I uploaded the others?
Yes upload to https://upload.symfonium.app
And yes the bug reports needs to be taken just after the issue.
Thanks.
Okay I’ve uploaded, hopefully I’ve done it right
Thanks, I’ve forwarded to Google they’ll tell.
You can enable the disable offload option to return to the beta build state you had.
Did you ever get the issue resolved regarding the payback stopping?
My Pixel 3 powercycles every 3rd song. I uninstalled the app from my phone and watch and reinstalled it but still does the same thing. Thoughts?
Always the same one ….
Open a proper issue?
