Sometimes during playback, the player does not reflect what song is playing. For example, if it reaches the end of track 4, the player gets stuck there, whilst playback starts playing track 5 as expected.
Trying to pause, okay, skip track again, doesn’t help - eventually playback just ends
Plex
Play an album without shuffle
After a few tracks, player gets stuck
Happens in casting, local playback and Bluetooth. No detected pattern of when it happens, it’s roughly every 1 in 2 album plays
You probably just need to force a sync in Symfonium if plex have changed it’s ids. But that does not explain cut in the middle of playback that would prevent playback start, this is a different problem.
Well I’m any case, performing a full sync seems to have fixed the problem for me - I’ve now managed to play 3 full albums whilst casting to the same speaker.
Not a massive sample size but it was happening so frequently before it’s very promising.
