Playback issue; music pausing randomly during queue and songs refusing to play
Whenever I start an automix or just randomly select a song it takes like 3-5 taps for it to actually start playing, it even just refuses to play and I have to choose a different song sometimes. I need help with this please
Upload description: Ayra19th
The logs are empty. I need logs reproducing the issue and more details at what you actually do.
Sorry wasn’t sure where to upload them
Well the wizard tells you everything as the FAQ :wink:
Done I just uploaded them online
your device can’t create the audiotrack but does not really say why :frowning:
Try to uncheck the option prefer internal decoder just in case.
just did and no luck sadly. Though I’ve noticed at random it just plays normally but when I exit and restart it goes back to acting like that
Do you use external EQ ? Only happen via BT ? (Try to change the codec in OS settings)
I don’t use any external EQ or any honestly and no codec setting is enabled. I’ve realized something though it seems to be working fine when I disable crossfade for some reason would be a shame to remove it yet it’s one of my favorite features to use
Try to upload a full bug report https://developer.android.com/studio/debug/bug-report after it happens. Maybe there will be more details about the OS error.
Be sure to use https://upload.symfonium.app and tell when done.
I’m done uploading it
There’s no bug report uploaded.
Sorry wrong file try checking now
Still wrong it should be a big zip file …
Yeah check the one I just sent rn
Unfortunately nothing more in the dump :frowning:
Oh, well that’s unfortunate
Try to reboot the phone and only use Symfonium after the reboot, in case it’s another app blocking old AudioTracks to see ?
No luck again I gotta disable smart fade for it to work right
Any chance you’re using bluetooth headphones and have do not disturb on? I found out earlier today that I get no bluetooth output when my device is on DND 🤷‍♂
